130s's avatar
130s
CAX80: [WLAN access rejected: incorrect security] from MAC
# Issue
  • Wifi gets disconnected. Occasionally it gets connected back, but then after indefinite period, many times it's a few seconds, it disconnects again. Then it takes a few minutes to sometimes 10 minutes to connects back without disconnection.
  • Observed on about 5 devices.
# Logs and more info
  • On router's admin webpage, "Advanced" -> "Administration" -> "Logs" I see these logs. The devices with those MAC address that got "[WLAN access rejected: incorrect security]" message correspond to those that are seeing the issue described above.:
[DHCP IP: 192.168.1.72] to MAC address xx:xx:xx:xx:9c:32 2 Sat Jul 10 11:10:02 2021 192.168.1.72:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC yy:yy:yy:yy:e9:2b 1 Sat Jul 10 11:09:46 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.72] to MAC address xx:xx:xx:xx:9c:32 1 Sat Jul 10 11:06:34 2021 192.168.1.72:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC xx:xx:xx:xx:9c:32 1 Sat Jul 10 11:04:06 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.72] to MAC address xx:xx:xx:xx:9c:32 4 Sat Jul 10 10:59:41 2021 192.168.1.72:0 0.0.0.0:0
[DHCP IP: 192.168.1.182] to MAC address yy:yy:yy:yy:e9:2b 1 Sat Jul 10 10:58:12 2021 192.168.1.182:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC yy:yy:yy:yy:e9:2b 1 Sat Jul 10 10:58:11 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.182] to MAC address yy:yy:yy:yy:e9:2b 1 Sat Jul 10 10:57:10 2021 192.168.1.182:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC yy:yy:yy:yy:e9:2b 1 Sat Jul 10 10:57:04 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.72] to MAC address xx:xx:xx:xx:9c:32 2 Sat Jul 10 10:55:55 2021 192.168.1.72:0 0.0.0.0:0
[DHCP IP: 192.168.1.182] to MAC address yy:yy:yy:yy:e9:2b 2 Sat Jul 10 10:55:06 2021 192.168.1.182:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC yy:yy:yy:yy:e9:2b 1 Sat Jul 10 10:54:11 2021 0.0.0.0:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC xx:xx:xx:xx:9c:32 1 Sat Jul 10 10:54:07 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.182] to MAC address yy:yy:yy:yy:e9:2b 1 Sat Jul 10 10:53:52 2021 192.168.1.182:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC yy:yy:yy:yy:e9:2b 1 Sat Jul 10 10:53:48 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.182] to MAC address yy:yy:yy:yy:e9:2b 3 Sat Jul 10 10:53:24 2021 192.168.1.182:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC yy:yy:yy:yy:e9:2b 1 Sat Jul 10 10:52:17 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.182] to MAC address yy:yy:yy:yy:e9:2b 1 Sat Jul 10 10:50:08 2021 192.168.1.182:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC yy:yy:yy:yy:e9:2b 2 Sat Jul 10 10:50:04 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.112] to MAC address ww:ww:ww:ww:90:56 3 Sat Jul 10 10:41:36 2021 192.168.1.112:0 0.0.0.0:0
[DHCP IP: 192.168.1.72] to MAC address xx:xx:xx:xx:9c:32 1 Sat Jul 10 10:37:45 2021 192.168.1.72:0 0.0.0.0:0
[DHCP IP: 192.168.1.143] to MAC address zz:zz:zz:zz:11:fa 1 Sat Jul 10 10:37:10 2021 192.168.1.143:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC zz:zz:zz:zz:11:fa 1 Sat Jul 10 10:36:08 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.143] to MAC address zz:zz:zz:zz:11:fa 1 Sat Jul 10 10:35:43 2021 192.168.1.143:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC zz:zz:zz:zz:11:fa 1 Sat Jul 10 10:34:26 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.182] to MAC address yy:yy:yy:yy:e9:2b 1 Sat Jul 10 10:34:18 2021 192.168.1.182:0 0.0.0.0:0
[DHCP IP: 192.168.1.143] to MAC address zz:zz:zz:zz:11:fa 1 Sat Jul 10 10:34:04 2021 192.168.1.143:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC zz:zz:zz:zz:11:fa 1 Sat Jul 10 10:33:10 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.112] to MAC address ww:ww:ww:ww:90:56 1 Sat Jul 10 10:33:00 2021 192.168.1.112:0 0.0.0.0:0
[DHCP IP: 192.168.1.143] to MAC address zz:zz:zz:zz:11:fa 1 Sat Jul 10 10:32:45 2021 192.168.1.143:0 0.0.0.0:0
[DHCP IP: 192.168.1.72] to MAC address xx:xx:xx:xx:9c:32 2 Sat Jul 10 10:32:42 2021 192.168.1.72:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC xx:xx:xx:xx:9c:32 3 Sat Jul 10 10:30:27 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.154] to MAC address ce:0b:ef:c8:ec:12 1 Sat Jul 10 10:28:14 2021 192.168.1.154:0 0.0.0.0:0
[DHCP IP: 192.168.1.72] to MAC address xx:xx:xx:xx:9c:32 3 Sat Jul 10 10:25:18 2021 192.168.1.72:0 0.0.0.0:0
[WLAN access rejected: incorrect security] from MAC xx:xx:xx:xx:9c:32 1 Sat Jul 10 10:22:54 2021 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.1.72] to MAC address xx:xx:xx:xx:9c:32 2 Sat Jul 10 10:22:31 2021 192.168.1.72:0 0.0.0.0:0
[DHCP IP: 192.168.1.154] to MAC address vv:vv:vv:vv:ec:12 1 Sat Jul 10 10:15:45 2021 192.168.1.154:0 0.0.0.0:0
[DHCP IP: 192.168.1.234] to MAC address uu:uu:uu:uu:d5:3b 3 Sat Jul 10 10:14:34 2021 192.168.1.234:0 0.0.0.0:0
# Environment
  • Nighthawk CAX80
  • Hardware Version: 1.01
  • Firmware Version V2.1.1.4
  • Cable Firmware Version V1.02.08
# What I did but didn't seem to work
  • Played with wifi setting, such as "Enable AX", "Enable Smart Connect" etc.
  • For 2.4 Ghz, change the channel from "auto" to the specific ones.
  • For 5 Ghz, change channels.
  • Got it working so far but not sure yet...as it had been working for a few weeks, then this occasionally bombers us. So in order for us to be confident I'd have to see a few more weeks. Anyways,
    # Change I made
    • Disabled guest network 2.4 ghz.
    • Disabled "Smart Connect" (so that the SSIDs for 2.4 and 5 ghz must be different, which is ok for us)
    # What I found before making those changes
    • Using wifi analyzer Android app the non-guest 2.4 ghz wifi and guest 2.4 ghz SSIDs are using the same channel. Without knowing much about those, I simply worried, hence the change described above.
    # Caveat
    • Obviously I cannot use guest 2.4 ghz wifi, which is inconvenient. If this is a bug I'd like to see a fix.
    • > # Change I made
         Did you determine that _both_ those changes were required?
      >   o Using wifi analyzer Android app the non-guest 2.4 ghz wifi and
         What led you to expect otherwise?  So far as I know, there's only one
      2.4GHz radio (which can use multiple SSIDs).
      >   o Obviously I cannot use guest 2.4 ghz wifi, [...]
         "Obviously", _if_ you determined that disabling the 2.4GHz "guest
      network" was required.  Did you?
