RicoLino
Jan 27, 2023Aspirant
CAX80 won’t factory reset and keeps dropping internet
I have been told to get in touch with DarrenM and @olympus1625 to discuss this issue. I have a netgear CAX80 and it just died. We have done everything possible to get it going with no success. We f...
Jan 27, 2023Guru - Experienced User
You'll need to contact NG and get his solved. There is nothing we can help with here in the forums:
Ask about an RMA.
RicoLino
In another thread, with the exact same thing happened with the exact same model, the poster was advised to reach out to the two people I mentioned. See this link. https://community.netgear.com/t5/Cable-Modems-Gateways/CAX-80-won-t-factory-reset/td-p/2262541
I’m not exactly sure how to use this forum well, especially on my mobile, if you have any help on contacting them, that would be great.
- FURRYe38Jan 27, 2023Guru - Experienced User
Yes, select on there user names and go to there profile pages and send them a Private Message.
