Moocow1980
Dec 03, 2021Apprentice
CAX80 won't work at all on WOW Internet; firmware update ruined it
Here's the deal. I just got in the mail today a replacement from Netgear for my CAX80. (Hindsight says I may not have needed it, but here we are.) I am with WOW Internet as my ISP in Columbus, O...
Dec 03, 2021Guru - Experienced User
What FW version is currently loaded? What FW was loaded for the router side of the modem?
Was the FW updated on the modem side from the ISP? Modem FW can ONLY be updated by the ISP.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Moocow1980
I can't check anything on it. How can I check the firmware if I can't even access it and pull info up on my laptop?
I also spent an hour with WOW having it provisioned. It won't receive the incoming Internet signal. They can send the refresh signal, and it refreshes, but no Internet.
All wiring and such has been redone from the cable hub outside, into my house, and into whatever I use the cable for, and it's all A-OK. I was getting the proper Internet speeds when I first got it in September. So none of that was an issue.
- FURRYe38Dec 03, 2021Guru - Experienced User
Can you access 192.168.1.1 or 192.168.100.1 in a browser?
- Moocow1980Dec 03, 2021ApprenticeNo.
Press the reset button for 10 seconds then release. Keep a wired PC connected to Port#4...
Try accessing the addresses again...
What are the front LEDs showing?
