Moocow1980
Dec 03, 2021Apprentice
CAX80 won't work at all on WOW Internet; firmware update ruined it
Here's the deal. I just got in the mail today a replacement from Netgear for my CAX80. (Hindsight says I may not have needed it, but here we are.) I am with WOW Internet as my ISP in Columbus, O...
Dec 16, 2021Guru - Experienced User
To FW update the CAX series the unit has to be in "Router" mode. It can't be in modem mode. The FW that is user updateable is ONLY for the router portion of the unit. The modem portion FW still comes from the ISP only. When in router mode, as long as the ISP Coax line IS connected to the CAX, the unit will not auto reboot. The Coax line doesn't have to be associated with the ISP or the modem has to be activated with the ISP, just as long as there a ISP modem signal on the line, the CAX will NOT auto reboot.
wziemer
Dec 16, 2021Star
Correct, my point was that in order to update the router firmware, you have to flip it back from modem mode to router mode; doing so make the modem unusable as myself and others have described in this thread. The only way i've found to actually get the CAX80 to work is in modem mode; even after factory resets, it works just long enough for you to speed through the setup and flip it over to modem mode, if you miss that window you have to power cycle and try again or it'll just get into a state where WOW says they see the modem fine on their end and all the LED's on the front of the CAX80 show a successful connection; yet the device does not hand out any IP's and does not work at all when left in router mode. It was perfectly fine about 2 months ago, then 'something' happened as others have reported where router mode no longer works.
- FURRYe38Dec 16, 2021Guru - Experienced User
Yes, and after the FW is updated on the router side, then you can change it back to modem mode.
Is there a differenet cable ISP in your town or is WOW the only on? One thing you can do IF, there is a different cable ISP in town and IF you know someone using that ISP, take the CAX80 to there place. Connected it to there coax line, don't do any association with it with the ISP. If the latest CAX80 FW already on a wired PC there. If you power up the CAX80, the unit should not auto reboot and maintain long enough for you to send the FW file to update the router portion of the CAX80. If you can get the FW loaded then you can factory reset and remove it and take it back to your place. Again this is corner case if this is an option.
Over all this is a WoW issue that they need to get working. My CAX80 is working fine with my ISP in router mode. I don't have the wifi radios enabled and using a different wifi system currently.
- ErnestTheGreatDec 16, 2021NETGEAR Employee Retired
FW 2.1.3.5 was recently released back on November 5th, 2021 however it was only an update for the router side so the DOCSIS part should not be affected. I am not sure how long the users here have been affected but it may be worthwhile to downgrade FW 2.1.2.6 to see if the same issue occurs. Also, Netgear is aware of the issue and they have a product engineer looking into it. For the users affected what are the LEDs on CAX80 doing when this issue happens? Also, it would be good to get a copy of Event Logs posted so that we have a better sense of what's happening from the ISP side?
