carson_adkins
Jul 09, 2020Apprentice
cax80 xfinity slow speeds netgear needs to fix this
another cax80 not getting full speed from xfinity there is a problem here just had a guy out to check the wires from xfinity and everything is great and tried to talk to xfinity and they sent signals...
Luis23ver
Sep 23, 2020Aspirant
I have the same problem here. Netgear send a new CAX80 but still the same slow speeds.
- FURRYe38Sep 25, 2020Guru - Experienced User
What devices are you using to speed test?
Try a wired PC or laptop to check wired speeds first.
Install wifi sweet spots app on your wireless device to check connection rate between the wireless device and CAX. This is just a connection rate, not speed testing the bandwidth.
