royybatty
Apr 17, 2022Aspirant
CAX80 Xfinity Speed Issues
So purchased a CAX80 because I upgraded to a 900Mbps plan on Xfinity. Anyone else having slow speed issues? Activated the device fine, connected to the 5ghz connection and ran a wireless speed test...
royybatty
Latest Firmware version.
Using MSI laptop and cell phone.
Shows Netgear channel is set to Auto and under 5ghz settings I changed that channel to 48.
Disabled Smart Connect, Armor Security and Traffic meter.
Picking up about 14 other networks in the area.
When I tested ethernet connection, I was getting similar speeds.
After the above changes, tested 131Mbps on phone, 121Mbps on laptop.
The coexistence setting only allows me to enable or disable the 20/40 setting. Does not allow me to select one or the other.
royybatty
Apr 18, 2022Aspirant
Okay so looks like the CAX80 just need to sit for awhile.....I know Comcast has told customers that it may take a few days for a new modem to fully get up to speed......just ran a speed test with laptop....hit over a gig on wireless. Ran ti again and hit 855. I can definitely live with that. Phone still struggles, only hit 255 down. Laptop does have Wifi 6 so that may be helping as well.
