royybatty
Apr 17, 2022Aspirant
CAX80 Xfinity Speed Issues
So purchased a CAX80 because I upgraded to a 900Mbps plan on Xfinity. Anyone else having slow speed issues? Activated the device fine, connected to the 5ghz connection and ran a wireless speed test...
royybatty
Latest Firmware version.
Using MSI laptop and cell phone.
Shows Netgear channel is set to Auto and under 5ghz settings I changed that channel to 48.
Disabled Smart Connect, Armor Security and Traffic meter.
Picking up about 14 other networks in the area.
When I tested ethernet connection, I was getting similar speeds.
After the above changes, tested 131Mbps on phone, 121Mbps on laptop.
The coexistence setting only allows me to enable or disable the 20/40 setting. Does not allow me to select one or the other.
Apr 18, 2022Guru - Experienced User
Might try channels 1, 6 or 11 on 2.4Ghz if you have a need for this frequency.
Had any of these been enabled before?
Do speeds decrease with SC enabled?
The coexistence setting only allows me to enable or disable the 20/40 setting. Does not allow me to select one or the other. Unchecking the check box next to this seeing then apply, sets 40Mhz only.
