cheekeongyip
Nov 10, 2021Follower
CAX80
I subcribe comcast for 1.2 GBPS but i only get 600 mbps and out of the 32 downstrean bonded chanel only 31 is lock no 32 is unlcok any idea how can i lock chanel 32
1 Reply
comcast doesn't lock channel 32. It leaves that for the ofdma link.
How are you testing speeds on the CAX?
What device?
What site are you using for testing?
Keep in mind, the only way you'll see over 1 gig speeds is if your pc is hardwired into the 2.5gig port and has at least a 2.5gig connection (the pc). Then test on comcasts speedtest site.
the built in speedtest site isn't accurate at greater than 500mbps speeds.
