Kc2023's avatar
Kc2023
Follower
Dec 28, 2022
CAX80
Hello -
I purchased a CAX80 router/modem combination and have been having super low download speeds varying to intermittent drops in connection.
ISP plan is for 1200 mbps vs CAX80 outputting 4-6 mbps. I have tried changing the channel, disconnecting APs and standing beside the router to only receive 4mbps speedtest.
Any ideas before I return this thing for an renting Xfinity router?
p.s. Any conflicts with using WAC510 APs?
1 Reply
  • FURRYe38's avatar
    What do you see with a wried PC connected to the modem?
    What devices do you have connected?
    What channels are you using?
    What if there broadcasting in same time and on same channels yes.
    What distances are the WACs from the CAX?
