KeepOnKeepinOn's avatar
Dec 12, 2021
CBK752 and Macbook Air/Monterey not connecting to internet
The competing model/description numbers give me a headache. I have the Orbi Model CBK752, which seems to mean Orbi Router CBR750 + a satellite (RBS750).   The Problem Brand new Macbook Air running...
  • FURRYe38's avatar
    Ok so while I was on hold with ATT, I was able to setup my CBR750 in AP mode behind my CAX80.
    I was just now able to get my Mac Book Pro with OSX 12.1 beta 4 connected to the CBR.
    Firmware Version
    V3.2.16.9_1.4.7
    I guess I can try updating to v4. :smileyfrustrated:
    I presume there maybe is odd issue with your Mac Book Air, OSX and the CBR750. You can tell Apple that my MBP works.
    Hopefully maybe they can help.
    Log in to your NG account and open a case here:
    https://www.netgear.com/support/#
    Other options as well maybe here:
    https://my.netgear.com/support/contact.aspx
