KeepOnKeepinOn
Dec 12, 2021Aspirant
CBK752 and Macbook Air/Monterey not connecting to internet
The competing model/description numbers give me a headache. I have the Orbi Model CBK752, which seems to mean Orbi Router CBR750 + a satellite (RBS750). The Problem Brand new Macbook Air running...
- Dec 16, 2021
Ok so while I was on hold with ATT, I was able to setup my CBR750 in AP mode behind my CAX80.
I was just now able to get my Mac Book Pro with OSX 12.1 beta 4 connected to the CBR.
Firmware Version
V3.2.16.9_1.4.7I guess I can try updating to v4. :smileyfrustrated:
I presume there maybe is odd issue with your Mac Book Air, OSX and the CBR750. You can tell Apple that my MBP works.
Hopefully maybe they can help.
Log in to your NG account and open a case here:
https://www.netgear.com/support/#
Other options as well maybe here:
https://my.netgear.com/support/contact.aspx
Dec 13, 2021Guru - Experienced User
Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Try disabling AX mode on both radios. Under the Basic tab/Wireless settings.
The Problem
Brand new Macbook Air running latest version of Monterey can't connect to the internet via Orbi wi-fi (primary or the guest) but can connect with other networks. Logged into Access Control - removed it from the Blocked list. Restarted everything, forgot the network on the Mac and reconnected. Now it doesn't even show up in the access control list of devices, but says it's connected on the Mac.
This shouldn't be this hard. What am I missing?
Thanks in advance!
- KeepOnKeepinOnDec 16, 2021Aspirant
Thanks Furry for the suggestions.
Did them both. No change. :robotindifferent:
Firmware: V4.6.5.8_2.0.54
