OddTodd
Apr 14, 2024Aspirant
CBK752 Did I choose wisely?
Really wish that I had found this a couple of days ago. Let me start from the top. I have Xfinity cable internet (just internet, no cable) that comes overhead via coax to my electric pole which is lo...
CrimpOn
Apr 14, 2024Guru - Experienced User
It's a "pro and con" thing.
- The combination device means one fewer component to find a location for, electrical power, etc.
- A separate modem means the modem can be replaced, upgraded, etc. much easier. the CBR750 is not designed to work with fiber.
I personally prefer a separate modem, but that's just me.
OddTodd
Thank you for the reply.
I see your point. As a matter of fact, it is possible that the modem part of my old modem/router was still working. However, I never bothered to plug anything into an ethernet port to verify. I don't recall when I bought it but, I would venture to say that it worked trouble-free for at least 8 years.
Any other input on the Orbi setup or my plan to use one in the shop via an ethernet cable?
Thank you
Thank you
- CrimpOnApr 14, 2024Guru - Experienced User
If you can fish an Ethernet cable through that tiny conduit, "go for it".
