KattyDidd
Jan 05, 2025Aspirant
CBK752 Router can't locate Satellite.
I have a CBK 752 which includes the Router CBR750 and Satellite RBS750, sold together as a pair. I cannot get them to pair, I have tried ALL the trouble shooting tips. Nothing works. I have turned...
Jan 05, 2025Guru - Experienced User
Had the RBS been working with the CBR up to this point?
Was FW on the RBS updated recently?
What FW version is on the CBR?
IF FW was updated on the RBS to v7 something, then you'll need to get v4 back on the RBS as v4 FW and v7 FW are not compatible and both CBR and RBS need to be at same level FW version to operate correctly.
KattyDidd
I can't find the FW specifically for the RBS only the CBR. I assumed since they were sold as a pair and the RBS is listed in "All my products" that they updated together. If that is not true, how do I find the FW update button for my RBS? As you can tell I'm not really literate in this.
- FURRYe38Jan 05, 2025Guru - Experienced User
Get any RBS750 FW that comes with a CBR from here:
