JasonM2610
Jan 23, 2025Follower
CBR40 connected to T-mobile gateway through MoCA adaptor
I have a T-mobile wifi gateway device for my house that only has ethernet connections. Can I connect my Orbi CBR40 with coax input to my existing gateway via ethernet through a MoCA adaptor?
Jan 24, 2025Guru - Experienced User
You can configure the CBR for a faux AP mode if your still wanting to use the wifi portion of the CBR and RBS.
