rxrush
May 28, 2024Tutor
CBR40 Modem Only Mode
Can someone please explain if I can turn CBR40 into a modem only mode and attach a different router (Asus, Eero etc.) to it? I see there is a bridge mode in the settings but does activating this mode...
May 28, 2024Guru - Experienced User
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
Yes, all but one LAN port will be disabled.
rxrush wrote:
Can someone please explain if I can turn CBR40 into a modem only mode and attach a different router (Asus, Eero etc.) to it? I see there is a bridge mode in the settings but does activating this mode disable the LAN ports, if the LAN ports are disabled how do you connect a different router to it? CBR40 does not have a WAN port from my knowledge. Thanks.
