Tweete18
Feb 26, 2024Aspirant
CBR750 internet issue after power outage
I had a CBR750 modem/router installed in a new home with Xfinity service and approximately 2 months ago we had a power outage. Long story short, the issue was found to be the router but Netgear would ...
Feb 26, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Any RBS deployed? If so how many?
RBS firmware loaded please.
Any front LED indications seen when this happens?
If the CBR is on a UPS, then would not be a CBR issue if the UPS maintained power to the CBR unit.
Tweete18
The 3 LEDs from the left to right will go solid but the last one will not lock on the Xfinity signal. I had a tech come and check the signal and everything checked out okay. I am actually using a leased Xfinity modem/router right now. This is the same behavior from both modem/routers that are no longer working. There is one RBS deployed. I am currently out of town but should have the firmware and event log for you once I return.
- FURRYe38Feb 26, 2024Guru - Experienced User
Ok, Will need to see those logs after the CBR is back online with the ISP.
FYI: There as been ISP infrastructure changes so this may play a roll in this as well:
Safe travels.
