Tweete18
Feb 26, 2024Aspirant
CBR750 internet issue after power outage
I had a CBR750 modem/router installed in a new home with Xfinity service and approximately 2 months ago we had a power outage. Long story short, the issue was found to be the router but Netgear would ...
Tweete18
The 3 LEDs from the left to right will go solid but the last one will not lock on the Xfinity signal. I had a tech come and check the signal and everything checked out okay. I am actually using a leased Xfinity modem/router right now. This is the same behavior from both modem/routers that are no longer working. There is one RBS deployed. I am currently out of town but should have the firmware and event log for you once I return.
Feb 26, 2024Guru - Experienced User
Ok, Will need to see those logs after the CBR is back online with the ISP.
FYI: There as been ISP infrastructure changes so this may play a roll in this as well:
Safe travels.
