bobismoore
Oct 08, 2024Aspirant
CBR750 with RBS750
I have a CBR750 cable modem/router with 1 RBS750 satellite. The satellite just disconnected out of the blue and i can't seem to get it reconnected. I've tried removing it, resetting it, resetting the...
- Oct 09, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 08, 2024Guru - Experienced User
Please downgrade the RBS750 back to v4 FW:
- bobismooreOct 08, 2024Aspirant
Thanks, but i have not upgraded. Was asking if i should.. Sounds like a no.. Hahaha!
- FURRYe38Oct 08, 2024Guru - Experienced User
Roger that. Ya keep v4 loaded. No idea if v7 FW will be forth coming to the CBR.
