bobismoore
Oct 08, 2024Aspirant
CBR750 with RBS750
I have a CBR750 cable modem/router with 1 RBS750 satellite. The satellite just disconnected out of the blue and i can't seem to get it reconnected. I've tried removing it, resetting it, resetting the...
- Oct 09, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
bobismoore
Hey CrimpOn!
Thanks for the reply..
the only evidence i have is that the satellite will not show up in the top of the devices screen where it should be. Also, i have about 32 devices connected, and the devices page shows a total of 14. And, my wife's laptop, which is about 6ft away from the satellite is only connecting at 72mb/s. Also, it shows up in the devices screen as being connected to the CBR750. This is why i am totally confused as to why it gives me the blue ring saying it's connected, when it clearly is not.
CrimpOn
Oct 08, 2024Guru - Experienced User
"My Bad" Did not read carefully.
- The Home Page says "1 satellite", but
- The Attached Devices page does not display the satellite (at all. no mention of status. Just not on the screen at all)
Crazy
