bobismoore
Oct 08, 2024Aspirant
CBR750 with RBS750
I have a CBR750 cable modem/router with 1 RBS750 satellite. The satellite just disconnected out of the blue and i can't seem to get it reconnected. I've tried removing it, resetting it, resetting the...
- Oct 09, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 08, 2024Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between CBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- bobismooreOct 08, 2024AspirantI’ll give all this a shot now that work is over. We both WFH so rebooting the router is a bit of a challenge during the day.
- FURRYe38Oct 08, 2024Guru - Experienced User
Understand that. At your convenience of course.
- bobismooreOct 09, 2024Aspirant
UPDATE!
1: Unplugged the CBR750
2: Let it sit while i factory reset the RBS750
3: Once i finally got the solid white light i hit the sync button and it connected and synced!
All is well again!
Thank you!
- bobismooreOct 08, 2024AspirantOh! To answer your questions.
It’s on the second story and the router/modem are downstairs. Definitely 30 ft away. And it’s a 2200sqft home built in 2003.
