bobismoore
Oct 08, 2024Aspirant
CBR750 with RBS750
I have a CBR750 cable modem/router with 1 RBS750 satellite. The satellite just disconnected out of the blue and i can't seem to get it reconnected. I've tried removing it, resetting it, resetting the...
- Oct 09, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 08, 2024Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between CBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
bobismoore
Oh! To answer your questions.
It’s on the second story and the router/modem are downstairs. Definitely 30 ft away. And it’s a 2200sqft home built in 2003.
