bobismoore
Oct 08, 2024Aspirant
CBR750 with RBS750
I have a CBR750 cable modem/router with 1 RBS750 satellite. The satellite just disconnected out of the blue and i can't seem to get it reconnected. I've tried removing it, resetting it, resetting the...
- Oct 09, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 08, 2024Guru - Experienced User
Understand that. At your convenience of course.
bobismoore
Oct 09, 2024Aspirant
UPDATE!
1: Unplugged the CBR750
2: Let it sit while i factory reset the RBS750
3: Once i finally got the solid white light i hit the sync button and it connected and synced!
All is well again!
Thank you!
- FURRYe38Oct 09, 2024Guru - Experienced User
Enjoy. 📡
