James_u_m
Jun 07, 2020Aspirant
Cg 3100 d Router setup
I purchased a cg3100d few months ago & did not use it till last week. I tried 2 use it as wireless router. I connected the the internet source 2 Netgear (NG) WAN port. The led indicator on NG was lit....
- Jun 07, 2020
Review the installation guide and user manualsl for setup information and use.
Try a factory reset as well.
Be sure your ISP supports this modem on there network.
Jun 07, 2020Guru - Experienced User
- James_u_mJun 08, 2020AspirantThanks for your reply. I did a factory reset & still didnot work. I dont use the modem port of cg3100d. I use standard cable modem provided by my isp provider. At present I use other brand wireless router & works fine.
- FURRYe38Jun 08, 2020Guru - Experienced User
Possible your modem/router if faulty or bad.
