george8688
Dec 28, 2018Follower
CG3000-2 STAUS struggling to create new IP and port for DVR camera
Hey,
I've purchased a 4 channel DVR camera system, and im trying to view the images off my mobile phoine. I've been trying to create a new IP and Port but when i go to www.canyouseeme.org it doesn'...
Nodism1125
Dec 29, 2018NETGEAR Expert
The www.canyouseeme.org will display the ISP public IP address not local IP address assign by the Cable modem/router.
Once you connect the 4 DVR wired to your network, the CG3000 will assign a Private IP (192.168.0.x). You need to access your cable modem/router configuration page and check the attached devices to view the dynamic address assigment of each DVR camera systems.
https://kb.netgear.com/000059644/Log-In-to-the-Cable-Modem-Router
Another way, install an IP scanner to detect all devices connected to your network. This will help you to find the Ip address assignment for each devices.
If you need to access DVR locally, find the private IP address 192.168.0.x.
If you need to access remotely, port forwarding is must.
https://kb.netgear.com/24290/How-do-I-add-a-custom-port-forwarding-service-on-my-Nighthawk-router
