FitzyNZ
Jul 15, 2018Aspirant
CG3000 router IPAD losing wifi signal
Hi there.
I have a CG3000v2 cable router with wifi through Optus. For some reason all apple ipads and iphones (we have tried 4 different IPADs) lose their connection after 30 seconds. YouTube will ...
wcalifas831
Jul 16, 2018Prodigy
Did you check to see if there are any firmware updates for that router? If there is maybe that could help. Of course from experience I know that apple products have issues with certain routers due to their securit in the apple firmware. It is a known issue with some routers.
FitzyNZ
Jul 18, 2018Aspirant
Hey I have swapped out the router from one of the rooms and it has stopped the issue. Everything is logging on now. Thanks for the help
