FitzyNZ
Jul 15, 2018Aspirant
CG3000 router IPAD losing wifi signal
Hi there.
I have a CG3000v2 cable router with wifi through Optus. For some reason all apple ipads and iphones (we have tried 4 different IPADs) lose their connection after 30 seconds. YouTube will ...
blackbmw1
Sep 06, 2018Aspirant
are you running NETGEAR Genie if not i suggest download it , just google it , that will help if it still does it then it might be a malware, sounds to me , so you can do a full malware scan and virus, if all fails try changing your modems braudcast channel pick a channel that your next doors dont have , , i go for channel 8 ..hope that helped
