Daan2254
Mar 03, 2021Initiate
CG3000D-1CXNAS
Hello , can someone please helping me with my Netgear password . I just forgot my password and now I can’t connect to the WiFi . Please helpe me. My Netgear Model CG3000D-1CXNAS
- Mar 03, 2021
If you hardwire into it, it bypasses needed the ssid password. Then you could log into the device to view what the ssid and password are. Or even change them.
How do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
or if that doesn't work,
you could always factory reset it and reinstall it. Push and hold reset for 7-15 seconds while its powered on.
