Cyclone90
Jun 15, 2012Novice
CG3000D Firmware
I just purchased a CG3000D Cable Gateway/Wireless router from Amazon. Supposedly new, put possibly not. I can't change the admin password beyond the default. It accepts the change, but doesn't actual...
jmizoguchi
Jun 16, 2012Virtuoso
That will NOT help you. That is for backing up router config and NOT firmware
romeocharlie
Jul 30, 2015Aspirant
i have the same problem and TW went into the http://192.168.0.1/ menu using their login credentials and they found NO WAY to update the firmware. they said there were no option for it on the screen & same for me (no option). so how is the service provider supposed to update if there is no update firmware option on the menu???
- DarrenMJul 31, 2015Sr. NETGEAR Moderator
Hello Romeocharlie
I have looked into the CG3000D this modem was orginaly sold to charter and wasnt a retail modem so we have no firmware support for this modem it would be handled threw the ISP here is a article talking about this. Sorry this dosnt help upgrade the firmware.
http://kb.netgear.com/app/answers/detail/a_id/24324/~/no-netgear-support-for-the-cg3000d
DarrenM
