ankitkshah2000
Dec 26, 2017Aspirant
CG3000D keeps rebooting
Hi, My wireless router is NETGEAR CG3000D-RG. It keeps rebooting itself. I am using Spectrum as provider and modem is owned by me. I am using TWC/Spectrum since year at same location and problem onl...
- Jan 03, 2018
Thanks Darren for reply. I had spectrum technician visting my house and checked all lines. They do not check modem-router as it is owned by me. So after researching over internet and trying different things following solution seems to be working.
1. Bought new A/C adapter for router from best buy (https://www.bestbuy.com/site/insignia-ac-adapter-black/5019131.p?skuId=5019131)
2. Untouched other settings in modem/router
Last 6 days not a single reboot observed! So I consider problem solved
ankitkshah2000
Dec 27, 2017Aspirant
hello, it just rebooted again at 8.50AM PST.
Downstream Bonded Channels | |||||||
Lock Status | Modulation | Channel ID | Symbol rate | Frequency | Power | SNR | DOCSIS/EuroDOCSIS locked |
Locked | QAM256 | 22 | 5360 Ksym/sec | 645000000 Hz | 8.7 dBmV | 42.5 dB | Docsis |
Locked | QAM256 | 23 | 5360 Ksym/sec | 651000000 Hz | 8.6 dBmV | 42.4 dB | Docsis |
Locked | QAM256 | 24 | 5360 Ksym/sec | 657000000 Hz | 8.4 dBmV | 42.3 dB | Docsis |
Locked | QAM256 | 25 | 5360 Ksym/sec | 663000000 Hz | 8.3 dBmV | 42.2 dB | Docsis |
Locked | QAM256 | 27 | 5360 Ksym/sec | 675000000 Hz | 8.7 dBmV | 41.9 dB | Docsis |
Locked | QAM256 | 28 | 5360 Ksym/sec | 681000000 Hz | 8.9 dBmV | 41.9 dB | Docsis |
Locked | QAM256 | 30 | 5360 Ksym/sec | 693000000 Hz | 8.2 dBmV | 41.7 dB | Docsis |
Locked | QAM256 | 31 | 5360 Ksym/sec | 699000000 Hz | 8.2 dBmV | 41.6 dB | Docsis |
Upstream Bonded Channels | |||||
Locked | ATDMA | 76 | 5120 Ksym/sec | 37000000 Hz | 40.3 dBmV |
Locked | TDMA | 73 | 2560 Ksym/sec | 18500000 Hz | 38.8 dBmV |
Locked | ATDMA | 74 | 5120 Ksym/sec | 23300000 Hz | 39.0 dBmV |
Locked | ATDMA | 75 | 5120 Ksym/sec | 30600000 Hz | 40.0 dBmV |
Current System Time:Wed Dec 27 16:53:01 2017
Top of Form
Bottom of Form
here is event log,
Wed Dec 27 16:50:51 2017 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0; |
Wed Dec 27 16:50:51 2017 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0; |
