ankitkshah2000
Dec 26, 2017Aspirant
CG3000D keeps rebooting
Hi, My wireless router is NETGEAR CG3000D-RG. It keeps rebooting itself. I am using Spectrum as provider and modem is owned by me. I am using TWC/Spectrum since year at same location and problem onl...
- Jan 03, 2018
Thanks Darren for reply. I had spectrum technician visting my house and checked all lines. They do not check modem-router as it is owned by me. So after researching over internet and trying different things following solution seems to be working.
1. Bought new A/C adapter for router from best buy (https://www.bestbuy.com/site/insignia-ac-adapter-black/5019131.p?skuId=5019131)
2. Untouched other settings in modem/router
Last 6 days not a single reboot observed! So I consider problem solved
ankitkshah2000
Dec 27, 2017Aspirant
hello,
it restarted again at 9.30AM.
ankitkshah2000
here is another reboot and message are,
| Wed Dec 27 18:45:47 2017 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0; |
| Wed Dec 27 18:45:47 2017 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0; |
| Wed Dec 27 18:35:04 2017 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0; |
| Time Not Established | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.0;CM-VER=3.0; |
- DarrenMDec 29, 2017Sr. NETGEAR Moderator
Your power levels are running a little high do you have a cable splitter connected to the modem if so try to remove that you also may want a tech from the ISP to come out and check your lines.
DarrenM
