ankitkshah2000's avatar
Dec 26, 2017
CG3000D keeps rebooting
Hi, My wireless router is NETGEAR CG3000D-RG. It keeps rebooting itself. I am using Spectrum as provider and modem is owned by me. I am using TWC/Spectrum since year at same location and problem onl...
  • ankitkshah2000's avatar
    Jan 03, 2018
    Thanks Darren for reply. I had spectrum technician visting my house and checked all lines. They do not check modem-router as it is owned by me. So after researching over internet and trying different things following solution seems to be working.
    1. Bought new A/C adapter for router from best buy (https://www.bestbuy.com/site/insignia-ac-adapter-black/5019131.p?skuId=5019131)
    2. Untouched other settings in modem/router
    Last 6 days not a single reboot observed! So I consider problem solved
