JBsafetyjb
Aug 31, 2016Follower
CG3000d no internet LAN 2 and 3 lghts flashing
On the front of the router the power, downstrem, upstream, and internet are all lite. The wireless botton lite is also lite. What could be the problem? However, the #2 and #3 LAN (ethernet) lights ar...
DarrenM
Sep 02, 2016Sr. NETGEAR Moderator
Hello Jbsaftyjb
Typically when those lights are flashing it just means activity on those ports. Have you called you ISP to see if they have any issues or can try to reboot your modem?
DarrenM
