Auslegung's avatar
Auslegung
Follower
Aug 02, 2016
CG3000D reset without me touching it
Information
Standard Specification CompliantDOCSIS 3.0
Hardware Version1.04A
Software VersionV5.5.4.mp2_CPR14c
Mac OS X 10.11.6.
We just moved this weekend, and are using our cg3000d again.  I'm on Cox internet, no TV.  Sunday and Monday the router wouldn't connect to the internt (internet light was mostly off, but would occasionally blink).  Monday evening it magically connected to the internet and was good all night.  This morning, about 30 minutes ago, it seemed to reset because the wi-fi name went back to the default name and password.  I logged into 192.168.0.1 and the login name and password were also back to default.  The internet light was blank again so no connection to the internet.
I couldn't see anything obviously wrong, but I did change the maximum number of connections from 255 down to 15.  Who needs 255 connections on a residential modem??  I also enabled NTP.  Anyway, it connected to the internet, I changed the wifi name back to my custom name and changed the passwords, and it's been fine for 20 minutes.  I have pasted the event log below.  I don't think reducing the max number of connections fixed it, nor enabling NTP, but I don't really know.
Why would the modem reset without me touching it?  Any recommendations on making this modem more stable?
Time
Priority
Description
 Tue Aug 02 10:09:13 2016
 Notice (6)
 TLV-11 - unrecognized OID;CM-MAC=84:1b:5e:c1:35:40;CMTS-MAC=00:1f:ca:1f:ee:65;CM-QOS=1.1;CM-VER=3.0;
 Tue Aug 02 10:09:12 2016
 Warning (5)
 DHCP WARNING - Non-critical field invalid in response ;CM-MAC=84:1b:5e:c1:35:40;CMTS-MAC=00:1f:ca:1f:ee:65;CM-QOS=1.1;CM-VER=3.0;
 Tue Aug 02 10:09:09 2016
 Notice (6)
 Honoring MDD; IP provisioning mode = IPv4
 Tue Aug 02 10:09:04 2016
 Warning (5)
 Admin login authentication fail
 Tue Aug 02 10:09:01 2016
 Critical (3)
 No Ranging Response received - T3 time-out;CM-MAC=84:1b:5e:c1:35:40;CMTS-MAC=00:1f:ca:1f:ee:65;CM-QOS=1.0;CM-VER=3.0;
 Tue Aug 02 10:08:58 2016
 Warning (5)
 Tue Aug 02 10:08:40 2016
 Notice (6)
 Time Not Established
 Warning (5)
 DHCP WARNING - Non-critical field invalid in response ;CM-MAC=84:1b:5e:c1:35:40;CMTS-MAC=00:1f:ca:1f:ee:65;CM-QOS=1.0;CM-VER=3.0;
 Notice (6)
 Critical (3)
 Critical (3)
 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=84:1b:5e:c1:35:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
 Warning (5)
 Critical (3)
 Warning (5)
 Critical (3)
 Warning (5)
 Critical (3)
 Warning (5)
 Critical (3)
 Critical (3)
 Warning (5)
 Warning (5)
 Critical (3)
 Warning (5)
 Critical (3)
 Warning (5)
 Critical (3)
 Warning (5)
 Critical (3)
 Warning (5)
 Critical (3)
 Warning (5)
