cupojo
Oct 08, 2016Aspirant
CG3000D-RG 802.11 g vs n
I have 2 laptops. Both Windows 10. Both with Wifi adpaters that say 802.11b/g/n in their properties. One Laptop connects at 802.11N, the other at 802.11G. How do I get the "G" laptop connecting at "N...
Retired_Member
Oct 08, 2016check the clients WIFI settings...... and for driver updates
- cupojoOct 08, 2016Aspirant
What settings are you referring to? And i've already checked for driver updates. I have the latest one.
- DarrenMOct 11, 2016Sr. NETGEAR Moderator
Hello cupjo
He is referring to your pcs wifi card settings.
DarrenM
- cupojoOct 11, 2016Aspirant
Yes I understand its the WiFi settings, but 'check the settings' is very vague. Which settings in particular under the WiFi settings? and what should the values be? thanks.
