cupojo
Oct 08, 2016Aspirant
CG3000D-RG 802.11 g vs n
I have 2 laptops. Both Windows 10. Both with Wifi adpaters that say 802.11b/g/n in their properties. One Laptop connects at 802.11N, the other at 802.11G. How do I get the "G" laptop connecting at "N...
cupojo
Oct 11, 2016Aspirant
Yes I understand its the WiFi settings, but 'check the settings' is very vague. Which settings in particular under the WiFi settings? and what should the values be? thanks.
DarrenM
Oct 12, 2016Sr. NETGEAR Moderator
Hello cupojo
This article might help
http://www.thewindowsclub.com/enable-802-11n-mode-wireless-connection-windows-8
DarrenM
- cupojoOct 13, 2016Aspirant
OK, so on to the next issue.
Under Advanced, Properties I have:
802.11d - (set to Disable), I changed it to enable, but it still connected at 11g
Associated Power Save
Beacon Interval
Preamble Mode
Roaming Sensitivity Level
TX Power Level
Wireless Mode (set to IEEE 802.11b/g/n) other options are 802.11b, 802.11b/g
There is no setting that says 802.11N.
And again, yes, I have the latest driver.
Adapter is RealTek RTL8191SE 802.11b/g/n
