Exsolaris
Dec 02, 2016Follower
CG3000D-RG Bridge Mode
Is it possible to put the modem/router into bridge mode my isp is cox and I do not see a option in the settings. The modem is connected to my Netgear WNDR3700v1.
DarrenM
Dec 05, 2016Sr. NETGEAR Moderator
Hello exsolaris
If there is no bridge mode on this modem the next best thing you could do is go to the LAN settings and disable the DHCP and also disable or hide the wireless then connect everything to your router.
DarrenM
