Vikram2's avatar
Vikram2
Follower
Nov 23, 2017
cg3000D routing function stopped working
Routing function of my device has stopped working. Ethernet port seems to be working fine. Can't get access to routerlogin.net/com as device is not wifi connected; so do not know how to check on router function online. Suspect it is a update issue as i have never updated it before and likey has no autoupdate option.
Any ideas or help in fixing this is really appreciated . thanks
1 Reply
  • > Routing function of my device has stopped working.
       What, exactly, does that mean to you?  It's not a useful problem
    description.  It does not say what you did.  It does not say what
    happened when you did it.  As usual, showing actual actions with their
    actual results (error messages, ...) can be more helpful than vague
    descriptions or interpretations.
       Does this gizmo have LED indtactors which indicate anything?
       Does that mean that you got an error page which said, "You are not
    connected to your Router's WiFi network. [...]"?  If so, then welcome to
    what may be the worst error message in the world.  For an explanation,
    try:
          https://community.netgear.com/t5/x/x/m-p/1365830
       Briefly, the idea is that "[www.]routerlogin.net" should point to
    your own router, but that's true only if you use your own router for DNS
    name resolution.  Irregardful, you should be able to get to the thing
    using its IP address, if you can determine (or guess) that.
       The User Manual for your router should tell you what its default LAN
    IP address is.  Look for "192.168.".  Otherwise, you can often get it
    from your (unspecified) computer's IP configuration as the default
    gateway or router address (or some similar description).  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.
