mwjscn
Jun 11, 2016Aspirant
CG3000Dv2 - Can't connect to game servers, general surfing is fine
About a little more than a month ago (had router for 3 years), I found myself unable to connect to game servers (across the board, no particular game in general) and some voice servers. The comput...
DarrenM
Jun 14, 2016Sr. NETGEAR Moderator
Hello Mwjscn
Are you gaming on a console or PC? Have you tried to port forward? I would also check your ethernet cords make sure its not a issue with them since you said the PC shows disconnected alot.
DarrenM
- mwjscnJun 19, 2016Aspirant
PC
As the OP says, I tried port forwarding without success. A port scan shows all ports as filtered, even when firewall is completely off and port forwarding is enabled.
I doubt it's an issue with the ethernet. Complete internet failure has only occured a couple times. I can browse the internet just fine, it just seems like something is blocking the connection to game and voice servers.
