Athaxto
Jul 19, 2016Aspirant
CG3000DV2 - chronic power cycling
I use COX as my ISP, and for the past month I've had chronic disconnect/reconnects through my router/modem. It will power cycle 5+ times per day, though it happens most often when I use a different w...
Athaxto
Jul 21, 2016Aspirant
Bump...still seeking assistance/expertise/advice with this issue.
- DarrenMJul 21, 2016Sr. NETGEAR Moderator
Hello Athaxto
T4 times outs are typically a issue with the cable signal itself I linked a article about this.
http://volpefirm.com/docsis_timout_descriptions/
DarrenM
- AthaxtoJul 27, 2016Aspirant
Thank you for the assistance, Darren. Hopefully that will be of great assistance when I get back home (if the problem persists).
