birdieagle
Feb 24, 2016Initiate
cg3000dv2 Devices drop internet intermittently
Information Standard Specification Compliant DOCSIS 3.0 Hardware Version R2.05A2 Software Version V1.02.10T Using with XFinity cable internet. Using this modem/wifi router for ab...
DarrenM
Mar 02, 2016Sr. NETGEAR Moderator
Hello Birdieagle
Have you adjusted the wireless channel on the router it could be something interfering with the wifi. We have a android app called Netgear wifi analytics which can show you what the best channel to set your wifi network on.
DarrenM
kdobbs09
Mar 25, 2016Initiate
I am having this issue as well. I have tried everything in the world I can think of. I tried 2 different cable outlets with a new cable, changed the channel multiple times, factory reset and gave it a new SSID and password and everything. When used with ethernet cable to my computer, it is smooth sailing, but the wireless does EXACTLY as OP described. Internet cuts out on all wireless connections, but the bars indicating connection to wireless router are full. I'm really not wanting to spend another $110 to be able to use my internet again. Anything else I can do? Thanks in advance!
Karen
