Neoteric
Mar 13, 2016Aspirant
CG3000Dv2 (N450) Massive lag spikes - Wired and wireless
Hello,
Could someone take a look at these ping reports and tell me what to do next? I tested both twc and yahoo, same results. I have a Netgear N450 Modem/router combo (firmware is up to date),...
- Mar 14, 2016
Well, thanks to you and a bit of a lightbulb moment I figured it out. It was my PLEX media server. Apparently the DLNA settings can cause huge lag spikes. Who knew???
Thanks! Problem solved!
TheEther
Mar 14, 2016Guru
Yes, if you are seeing it with simultaneous pings to all 3 sites, where one of them is your router, then the problem is on your end. Do you have QoS enabled on your router? If yes, try disabling it. Sometimes, QoS is more harmful than helpful. What other features have you turned on in the router?
Neoteric
Mar 14, 2016Aspirant
The only place I found a QoS option was for wireless multimedia, and I turned it off (didn't fixi t). I haven't messed with any of the default settings otherwise.
- NeotericMar 14, 2016Aspirant
- TheEtherMar 14, 2016Guru
Great. Go back and turn WMM back on. Wireless speeds will be crippled without it.
