Neoteric
Mar 13, 2016Aspirant
CG3000Dv2 (N450) Massive lag spikes - Wired and wireless
Hello,
Could someone take a look at these ping reports and tell me what to do next? I tested both twc and yahoo, same results. I have a Netgear N450 Modem/router combo (firmware is up to date),...
- Mar 14, 2016
Well, thanks to you and a bit of a lightbulb moment I figured it out. It was my PLEX media server. Apparently the DLNA settings can cause huge lag spikes. Who knew???
Thanks! Problem solved!
Neoteric
Mar 14, 2016Aspirant
The only place I found a QoS option was for wireless multimedia, and I turned it off (didn't fixi t). I haven't messed with any of the default settings otherwise.
Neoteric
- TheEtherMar 14, 2016Guru
Great. Go back and turn WMM back on. Wireless speeds will be crippled without it.
