Retired_Member
Jul 16, 2016CG3000Dv2 (N450) Router 2 in 1 Lag Spikes HUGE
So,what happened is that I got a new router and I do some online gaming such as agar.io , slither.io , and diep.io.I think it has something to do with the ping.I have not tried anything yet but I hav...
Retired_Member
Jul 17, 2016If your ISP supplied the CG3000Dv2 contact them directly.
- Retired_MemberJul 17, 2016
no my isp didnt give me the router :(
- DarrenMJul 19, 2016Sr. NETGEAR Moderator
Hello BeastWolfYT
I would try to adjust the wireless channel to get a better connection you may also want to look and see if you need to do any port forwarding for those games.
DarrenM
- Retired_MemberJul 19, 2016
The model number as posted doesn't even come up using above download link???????????????????????
