invalidation
Nov 03, 2016Guide
CG3000DV2 (N450) WMM settings missing from new firmware / general wireless failure.
I'm trying to disable WMM, as I suspect it causing an issue, however the options for it don't seem to be in the latest firmware issued by TWC / Spectrum (V3.01.06). I've read that it's under `Adv...
TheEther
Nov 04, 2016Guru
I would recommend not disabling WMM. If you do, you'll be limited to 802.11g speeds, which will max out at around 22 Mbps.
- invalidationNov 04, 2016Guide
I'll take that under advisement. That's still a higher speed than I'm getting from all my wireless devices (averaging 4-5mbps down and 20mbps up across multiple tests on a 200/20 internet connection).
Devices, when wired, are achieving full speed.
- TheEtherNov 04, 2016Guru
WMM is unlikely to be the source of your speed issues. Try changing the Wi-Fi channel. The current channel may be congested by nearby Wi-Fi networks.
