invalidation
Nov 03, 2016Guide
CG3000DV2 (N450) WMM settings missing from new firmware / general wireless failure.
I'm trying to disable WMM, as I suspect it causing an issue, however the options for it don't seem to be in the latest firmware issued by TWC / Spectrum (V3.01.06). I've read that it's under `Adv...
TheEther
Nov 04, 2016Guru
I would recommend not disabling WMM. If you do, you'll be limited to 802.11g speeds, which will max out at around 22 Mbps.
invalidation
Nov 04, 2016Guide
I'll take that under advisement. That's still a higher speed than I'm getting from all my wireless devices (averaging 4-5mbps down and 20mbps up across multiple tests on a 200/20 internet connection).
Devices, when wired, are achieving full speed.
- TheEtherNov 04, 2016Guru
WMM is unlikely to be the source of your speed issues. Try changing the Wi-Fi channel. The current channel may be congested by nearby Wi-Fi networks.
