creeves
May 18, 2020Aspirant
CG3000Dv2 wifi 20% the speed of ethernet
Hi everyone I have the issue as MayBTime2Change I have a N450 CG3000Dv2 and my internet service plan is for up to 100mbps. Plugged directly into the ethernet port I realize the full 100...
May 18, 2020Guru - Experienced User
450Mbps is a connection rate between the modems wifi and a wifi device. Not actual speed thruput or bandswidth.
Depending upon your wireless devices support and design will factor in what actual speeds you may see.
- creevesMay 19, 2020Aspirant
Hi and thanks for the reply
I should have specified that all my wireless devices, of various types, are experiencing the 20mbps bandwidth. So it seems that the router is reducing the wifi speed available for some reason.
I would expect wifi to be slower than a direct ethernet connection, but 80% slower seems excessive.
- FURRYe38May 19, 2020Guru - Experienced User
The modem and wifi on this modem are a bit older. You may want to consider getting into a new gateway modem or a modem only and then attach on external wifi router of your choice for better wifi performance.
