Fuzzzz
Aug 20, 2015Follower
CG3000DV2 Wifi issues
Had this router for about a year or so and it looks like about a month ago I started having the same annoying issue - internet connectivity problems on mobile wifi devices. Everything wired always wo...
MeredithG
Nov 18, 2015Tutor
Same issue -- worked fine for a couple of months and then slow-no reach to where it previously worked. Infuriating, especially given the price of this modem-router. Comcast/Xfinity says it's not a cable issue on their end, no way to check if the firmware has been updated, and I cannot spend time powering down, unplugging everything, and powering up. Help! Should I just ditch this Netgear device and get another...switch to Linksys??
DarrenM
Nov 19, 2015Sr. NETGEAR Moderator
Have you guys tried to tell your mobile devices to forget the network and try again? you may also want to try and change the SSID and the security type on the wireless I have seen this fix strange issues with mobile devices on wifi.
DarrenM
