Fuzzzz
Aug 20, 2015Follower
CG3000DV2 Wifi issues
Had this router for about a year or so and it looks like about a month ago I started having the same annoying issue - internet connectivity problems on mobile wifi devices. Everything wired always wo...
MeredithG
Nov 20, 2015Tutor
My issue isn't with a mobile device but with a laptop being used two floors down from the router. Was working fine until a few weeks ago.
DarrenM
Nov 20, 2015Sr. NETGEAR Moderator
MeredithG
Has the signal to the laptop gotten weaker or is it just not connecting? and I would still try what I suggested with the mobile devices with the laptop to see if anything works. also try disabling the password just to test to see if the laptop will connect.
DarrenM
- mjscott99Nov 20, 2015Tutor
Here's an update on the issue I've encountered, and appears to be the same as others are experiencing. I changed the wireless channel, but it hasn't fixed the problem. Every 2-3 weeks the wireless function seems to become paralyzed and all connected devices are unable to access the internet. Rebooting the router has been the only way to get it working again. Nothing from the wireless device end (phone, tablet, laptop; resetting connections, deleting connections, rebooting devices) has worked.
It's been worse a couple of times. The wired connection has also stopped - don't know if the router has crashed at that point or what. A hard reboot fixes the problem, at least temporarily.
I've never had such reliability problems from a router before. Quite disappointing.
Is it more likely that this is a hardware or software issue?
- MeredithGNov 20, 2015Tutor
Who would know since there's no way for customers to actually know if there have been any updates and if they've been installed. For this model, all that allegedly goes directly to the ISP.
<sigh> I think I'm going to have to take a loss on this equipment, ditch it, and go with another product. This is irritating and time consuming. Too bad, I've always used Netgear but this router modem seems to be a dud.
