gdash
Apr 13, 2016Aspirant
CG3000Dv2 wrong time, NTP missing in GUI
Hi There, Recently my CG3000Dv2 router firmware upgraded. Comcast is my ISP. Now I have intermittent issues. While chekcing the modem time shows 1 hour lag behind the network time. The last firmw...
TheEther
Apr 14, 2016Guru
Factory reset only erases settings. It does not restore the original firmware. Usually, you go to support.netgear.com, enter your model number and download firmware. Unfortunately, I don't see any firmware downloads for your model. Often, firmware for cable modem/routers is not upgradable by users.
gdash
Apr 14, 2016Aspirant
So what is the solution for my model? Please help. Dont want to spend money again.
Thanks in Advance.
- DarrenMApr 14, 2016Sr. NETGEAR Moderator
Hello gdash
Are you able to provide some screenshots of your event log page and the cable connection page so I can send this over to our engineers to investigate the issues. and when you talk about intermitten tissues are you talking with the Wifi or with the internet or with both?
- gdashApr 15, 2016Aspirant
Hello Darren,
I have attached the screenshots of the cable connection page & event log page. When I say intermittent issue, that means wireless as well as wired connections are having problem. But most frequent is my wifi.
- DarrenMApr 15, 2016Sr. NETGEAR Moderator
Thanks for the screen shots I will send them over to see what we can figure out.
DarrenM
