goodmen116
Aug 18, 2019Aspirant
CG3000v2 network priority control
Hi there, I was wondering if anyone knows how to set up network priority on a CG3000v2 router. While I can find broadband control it is only for the entire router and not specific devices. My router...
- Aug 20, 2019
Looks like this maybe a ISP provided modem. I see no user manual for it. Only a QIG. There is something about optus.com.au there.
I would contact your ISP for additional help and information about this.
goodmen116
Aug 20, 2019Aspirant
Thanks, you are correct it is a replacement modem given after our last one was damaged during a thunderstorm. This may explain the lack of features. I will contact my ISP.
Thanks for your help
Aug 21, 2019Guru - Experienced User
Good Luck. :smileywink:
